Hi There,
Need an alternative for a Midori potentiometer CP-2FK(b)-10K.
We would purchase these and place on our hydraulic actuators for our customers, but they are no longer providing this it seems. The specs can be found on their page – https://www.midoriamerica.com/wp-content/uploads/2019/05/cp2fkjseries-2019.pdf
We need a new source and hope DIGIKey can provide.
Thanks
randy.stinson
Thank you for contacting DigiKey , the closest option I am finding is part number 716-157S103MB9002-ND check data sheet to see if this will work for you . https://www.vishay.com/docs/57042/157.pdf
Thanks Craig
Hi Craig,
Thanks for the support and response.
Are you able to provide a quote for 10pcs with a lead time?
thank you Craig, that will work
randy.stinson
For a quote you can send an email to quotes@digikey.com
Thanks Craig
Please note that registered users may self-generate quotes by adding the desired products to a list
and when complete, using the “Create Quote” button on the list view. This approach typically yields a result in minutes rather than days, as is typical for quote requests submitted via email. Note also that price/availability/lead time information are available on the product detail page, pictured above
Thanks Rick, will check that out!
