Need capacitor value
I want to know the value of this capacitor. BkO-CA1487-H04. Thanks for your help.
@azfar3
I too am not able to verify the specs for that item based on the given item numbering.
Would you have an image of the marking that item has?
Here is image attached. Thanks for your help.
Hello @azfar3,
This is a challenge.
I’ve searched the Nichicon catalog with no success. I’m let to believe this a very old series or a custom designed product.
I’m confident DigiKey has a replacement, but we need to know more about the product and appliation.
Request to you provide:
  1. a picture of any other capacitor markings.
  2. Identification of the equipment manufacturer and model number. There is a small chance that we will be able to locate a schematic.
  3. Any internal equipment markings or schematic that could provide a clue.
Best wishes,
It is being used in Mitsubishi A800 Drive, 600V 20HP. Two same capacitors are being used. 64mm Dia and 91mm height. Let me know if you can offer replacement. Thanks.
Sorry, @azfar3,
I don’t have a definitive answer. Based on the capacitor size, DigiKey has these options. Unfortunately, without knowing more about the drive’s requirements, we would be guessing. A mistake could result in an explosion of the capacitor within the drive rendering the entire unit scrap.
Recommend you contact a service provider specializing in drive repair. You may be able to purchase a refurbished unit using your existing drive as a core return (like a car’s alternator). Another option is to purchase a new drive.
Again, my apologies, I have exhausted the tools at my disposal.
Sincerely,
Aaron
We have sent this request and we are waiting to see if Nichicon can verify what the values are on this capacitor. We are still waiting. Hoefully they have some information. We will update when we get a reponse.
We did receive a response and the supplier stated they are working directly with you on this part.
