Specifically what I need is the correct size. The capacitors in question are rather large.
@mwgulas
Would you happen to have the dimensions for these?
1000uf 16v(at min) options
330uf 50v(at min) options
50v 330uf is 25mm tall, 12mm wide. 1000uf 16v is 15mm wide 25mm tall. These measurements are approximate.
How about 493-1612-ND CAP ALUM 330UF 20% 50V
P1171-ND CAP ALUM 1000UF 20% 16V RADIAL
Thank you. I have ordered those parts.
