Need help identifying inductor
Hi all, I’m having difficulty identifying L103 here. I believe it’s 10uH but it could also 1.0uH? I’d also like to know for the tolerances. Thank you so much
Hello dang2150, welcome to the TechForum!
Size Questions
I think I see a decimal between the 1 and 0. Do you have measurements including the following:
Length
Width
Distance between pads
Current Rating Questions
There is a trace coming off the right side of the inductor, could you give us the approximate width and tell us the thickness of the board? This should give a rough idea of how much current is at least going through the item.
