Need help identifying these connectors - Loren Cook Exhaust Fan
I’ve got these serial cables for the Loren Cook 101 ACRU 101R28D VF Exhaust Fan. They are used to connect the US Motors PerfectSpeed module to the motor. We are looking to make our own cable assemblies as the ones we have purchased from the manufacturer keep failing in the same way.
Thank you for your post.
It is a little difficult to tell, but I believe the larger of the connectors would be one of these four from TE Connectivity - 4 Rectangular Connector Housings | Rectangular Connectors | Electronic Components Distributor DigiKey
The smaller of the connectors I am not sure since we do not know the pin spacing. I can get close, but you will need to check the distance from the center of one contact to the center of the next contact. Here is a link to our category that I believe it will be in - 4 Rectangular Connector Housings | Rectangular Connectors | Electronic Components Distributor DigiKey
Thank you! This helps narrow down the search, I believe I found the two connectors needed.
