Need help identifying this connector
This is a connector MinnKota uses on their Power Drive control boards. I am trying to find the mate to this and when I call Johnson Outdoors they are less than no help. Any help is greatly appreciated
Hi,
Welcome to the Digikey tech forum. Do you need a mate that is panel mount or cable mount. What trolling motor model do you have ?
Hi Steve,
Here is an image of the actual connector we are trying to source. It is cable mount. We use the Riptide Power Drive 55lbs motors. https://www.marksetbot.com
Thanks
Jim
I did some research and I’m not able to find the actual manufacturer of the connector or find any part numbers from MinnKota for the connector only. Looks like they sell this as a control board unit , Minn Kota PowerDrive CoPilot Control Board - Trollingmotorparts.com . I checked similar connectors in our system and wasn’t able to come up with a good match.
