I need help to find the cord that is compatible to SDM120-UD
The IEC connector should be 320-C8
Greetings,
I believe you’d actually want to look for a cable with a -C7 connector. Datasheet lists the jack with which it’s equipped, though the corresponding plug typically has an odd number in the IEC designation system.
Also, accessory items of the sort are frequently mentioned near the bottom of the product page.
Hello tsabic,
You can look at all the option in the link in rick_1976’s message. If you need help narrowing it down, let us know what connector you need on the input side of the cable, and how long you need the cable. We can then narrow down the choices.
