NEED INPUTS ON THE BATTERY - LIR18650 2600mAh
We have battery requirement with the rating - LIR18650 2600mAh to purchase. Could you please provide the below parameter values for the battery - LIR18650 2600mAh -
Bulk Capacitance (Cb)
Surface Capacitance(Ccs)
Internal Resistance (Ri)
Polarization Resistance (Rt)
Voltage across bulk capacitor (Vcb)
Voltage across surface capacitor (Vcs)
Battery pack terminal voltage(Vo)
Battery pack terminal current (I)
Could someone help me in finding the above values to go ahead with the battery purchase
Thanks & Regards
Kumar
Hello Kumar,
Thank you for your inquiry. Please verify if one of below products will work for you, as these are the best options we currently stock. If the information isn’t listed on the datasheet, we can inquire further with our product manager:
Click here for 1568-1488-ND | 1568-1490-ND | 1908-1344-ND
