When ordering Norcomp panel mounting kit 160-067-010R033, you may need to know what the material composition of each of its pieces are, or what the dimensions of the mounting jackscrews are. This information isn’t available in the product’s datasheet , but you can check it out below.
1. Material composition of each parts in Norcomp 160-067-010R033
- Washer => Steel; Nickel Plated
- Teflon Washer => PTFE
- Lock Washer => Stainless Steel
- 4-40 Nut => Steel; Zinc Plated
- Jack Screw => Brass; Nickel Plated
2. Screw Dimensions
