Hi @vairamhcet, sadly while the name is very similar “RTLinux” vs “Real-Time Linux” it is a completely different project…
There is no relation between the “Real-Time Linux” kernel you are booting on the BeagleBone Black and the “RTLinux” project you are trying to utilize from tldp.org & cs.uccs.edu websites.
The “RTLinux” project was discontinued by Wind River in 2011:
All the instructions you’ve found on tldp.org are out of date and do not apply to the “Real Time Linux” kernel.
Where as the “Real Time Linux” project is an active project around mainline PREEMPT_RT:
Short answer, even if you find an “rtl.mk” it will NOT work with “Real-Time Linux”…
To write “Real Time Linux” applications follow these application guides on the wiki
