Ordering extra parts IN100
I received your goods, the IN100 DEVELOPMENT KIT, BLE5.1 CO, in good order and I am impressed.
Thank you.
Now I would like to order some more but obviously I don’t need more Programerboards.
Is it me or??? I can’t find the right IN100 with antenna input as delivered in the Development KIt.
I would also like to order Antenna’s that are needed for these boards.
Please send me the appropriate article numbers for ordering.
Greetings,
I do not see an indication that the development boards are available separately. This would not be uncommon, since chip manufacturers often wish to discourage use of evaluation hardware as a production item.
The documentation appears to indicate that an SMA -type antenna connector is used. There is a large number of such products available that work in the 2.4 GHz band.
Please note that both SMA and RP-SMA connectors are in common use, with the difference being the form of the central contact compared to the outer contact.
