This Product Selection Guide contains information to help select products in the Panel Mount category on DigiKey.com
Panel Mount Terminal Blocks are used as a main connection point with one or more terminals separated by a plastic barrier. The device is meant to be mounted on a panel and allows connections between circuits on both sides of the panel. The panel wire connections are bolt/screw clamp, header/male/female, circular clamp, PCB pins, push in clamp, quick connect, screw terminal, solder eyelet, solder tabs, and wire wrap terminals.
SelectionCharacteristics
Front Panel Wire Connection: Indicates the mechanical form of the connections on the front/exterior side of the device.
Rear Panel Wire Connection: Describes the form factor of the connectors on the terminal block that are located behind the panel to which the block is mounted.
Width: Indicates the overall width the device.
Panel Thickness: Indicates the thickness of an enclosure wall or similar planar surface into which a device is intended to mount. May be unspecified for products having a geometry that is insensitive to this dimension.
Positions Per Level: Indicates the number of independent circuits present in a device along each level, row, or tier of contacts.
Panel Mount Type: Describes the mechanical form factor of a terminal block’s panel attachment mechanism.
Pitch: Indicates the center-to-center spacing between adjacent pins.
Voltage - UL: The rated maximum working voltage of a device, per standards established by Underwriters Laboratories.
Current - UL: Indicates a device’s maximum continuous current rating, per standards established by Underwriters Laboratories.
Wire Gauge: The wire size or size range with which a product is designed for use, typically expressed in terms of AWG (American Wire Gauge).
Color: The dominant color of the device.
Features: These are different capabilities or properties of the device such as ground, sealing gasket, or threaded mating lock.
Number of Levels: Indicates the number of rows of contact positions incorporated in a device, called “levels” in reference to the rows’ varying distance from the mounting surface.
ProductExamples
| MFR PART # | 1861154 |
| DIGIKEY PART # | 277-6543-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | 2 Position Terminal Block Header, Male Pins Green |
| MFR PART # | 1899294 |
| DIGIKEY PART # | 277-9005-ND |
| DESCRIPTION | 3 Position Terminal Block Header, Male Pins Green |
| MFR PART # | 1936620000 |
| DIGIKEY PART # | 281-5986-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | 1 Position Terminal Block Bolt/Screw Clamp - Wire Entry 90° to Panel Green, Yellow |
| MFR PART # | 1821070 |
| DIGIKEY PART # | 277-10372-ND |
| DESCRIPTION | 4 Position Terminal Block Push In Clamp - Wire Entry Angled to Panel Granite |
| MFR PART # | 708360 |
| DIGIKEY PART # | 277-10660-ND |
| DESCRIPTION | 1 Position Terminal Block Bolt/Screw Clamp - Wire Entry 90° to Panel Gray |
