Part Dimension Clarification for ITT Cannon DLM5-260P Connector
If you observed any dimension mismatch in part DLM5-260P from ITT Cannon, LLC:
According to the current datasheet on the website, dimension “G” is listed as 26.00 ± 0.2 mm, but the actual observed dimension is 30.10 mm.
Please note that we have verified this with manufacturer and referred to drawing below. The correct dimension for “G” is 30.5 ± 0.8 mm.
Kindly refer to the attached drawing and redline below.
CU-127050-0109_A-STAMPED.1.pdf (150.8 KB)
127050-0474_B.pdf (165.8 KB)
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
1003-1660-ND DLM1-156R
1003-1661-ND DLM3-60P
1003-1680-ND DLM2-96P
1003-1679-ND DLM1-156P
1003-1657-ND DLM6-360R
1003-1658-ND DLM5-260P
1003-1662-ND DLM3-60R
1003-1681-ND DLM2-96R
1003-1659-ND DLM5-260R
1003-1656-ND DLM6-360P
