I need the opposite of pert # 839-1489-ND and need help finding the part #. Need I need, 2 male ends where the females are and 1 female where the one wrong male
Hello jcook,
I was unable to find the 839-1489-ND part number, so I could not verify the size of the plugs you needed. I searched for cables with 2 plugs to 1 jack, and found some with the 2.1mm X 5.5mm barrel size. The part numbers I found are 1528-1467-ND, 839-10-02737-ND, and 1738-FIT0884-ND. Please check the specifications and the datasheet, if available, to verify compatibility to your application.
839-1489-ND is an old part number for 10-02265 (839-10-02265-ND) from Tensility International Corp you can see this by scrolling down to the other names section on the PDP. It is quite different from the cords in your picture.
