Hi, Trying to find an match to the following part. Its a 4m X 5mm 8 pin SOIC. Found in a crude DC → AC inverter driving the output stage driving FET’s.
Hi iaeinfach
I was not able to verify this part. I have sent a request internal to see if others are able to assist. I have not received any responses yet. If I do, I will share them.
Hello Adam7,
I am sorry, I was unable to locate any specifications for an IC with those markings.
I’m in need of identifying this part so I can order a new one.
I broke off the support piece that covers one side of the pins
Any help is much appreciated!
Hi haleyjlindley,
Can you provide more photos from different angles? I wasn’t able to locate something that looked similar. Can you also provide the pitch dimension? That would be the distance between the center of each pin or socket within that connector.
Thanks,
