Part information
I purchased a
2368-54-718-ND
54-718
SWITCH TOGGLE DPDT 3A 125V
on order #Redacted for safety
on 11/10/23
I want to replace it with a SWITCH TOGGLE DPTT 3A 125V
I want it to look just like my DPDT and fit in the same hole.
I cannot seem to find specs on the DPDD that I have, so am lost trying to search for DPTT
Can you help me?
Hello gappel69 and welcome to the DigiKey TechForum.
From what I could find about 2368-54-718-ND, it appears to have a 13.3mm long actuator and have solder lug termination. Unfortunately, I have been unable to find a panel cutout dimension for this part.
If by DPTT you are meaning you want a Double Pole, Triple Throw. I was able to find the options linked HERE that are the closest to the specifications you listed. They are rated for 5A 120VAC and have a range of actuator lengths from 10.67mm to 17.45mm.
If you mean something different than DPTT, can you please explain.
Thank you very much nick_13812.
I think the 7411TZQE is going to do exactly what I want.
Thanks nick_13812
I think the 7411TZQE is going to be just what I need.
