Relay
Can you suggest a DPDT or SPDT relay with a length below 10mm, width between 6 to 8mm, and any height?
Hello @nisarga.mj
Welcome to community!
Can you please confirm the coil voltage and the load voltage/current to be switched, so we can narrow down our search.
Hello @nisarga.mj,
The specified relay is on the small side of the spectrum. Thankfully DigiKey has many that may meet your requirements. As an example, consider:
As @aayushi.nainwal pointed out, we need more information to narrow down the selection.
Best wishes,
