I have this item: 360-2089-ND S332. I would like to know if you have a mini-switch version of this? I need the smaller form factor. Thanks!
Hello @tethomas_99,
The physical dimensions of the toggle switches are not listed in the filters. Each datasheet would have to be reviewed for the measurements. That being said, there is one way to sort the smaller toggle switch options on the site. Pull up the toggle switch category here. Filter out DPDT, Panel Mount, and Switch Function (On-On). Then the filters should look like this https://www.digikey.com/short/48zf523b. Next go to the “Bushing Thread” size filter and apply the filters to the smaller bushing thread size. This should help narrow down the similar smaller switch options.
Thanks!
-Jeff
Similarly, you can filter on “Panel Cutout Dimensions” and/or “Actuator Length” to find ones that are more of the scale you desire.
For reference, the 360-2089-ND (S332) uses a 12.5mm (1/2") panel cut-out and has a 17.5mm (0.69") actuator length.
