Hi,
I am looking for the switch in the link.
Link: Honeywell Microswitch - US20D20C00 - Switch, Micro, Flat Lever. Contacts: SPDT.
I checked online but, only one store seems to stock this part. Can you help me find it on your website or a similar one with the same dimensions.
Dimensions:
Body: 7.5mm long x 2.5mm wide x 4.1mm high.
Kind Regards,
Rovin
Hi @Astrorovin_98, please check AV4424619-ND from Panasonic whether it is suitable your design.
Hello Rovin:
This switch is not as small as the one you’re looking for, but it is in stock: 450-2035-ND The dimensions on this are 12.8 x 5.8 x 6.65, but hopefully it would work for your application.
Hi Astrorovin-98,
According to the datasheet I found for the US20D20C00, it has silver contacts rated for 500mA. Therefore, I would recommend the 255-3743-ND (Panasonic p/n AV4424).
Looks like a drop-in replacement.
