The concept shown in the image above is/was an “intelligent” lighting system made by Color Kinetics. Such systems require the integration of power conversion and communication functions into each luminaire. While Digi-Key does offer a wide variety of components of the sort used to engineer such systems, we do not carry finished products of this type at the current time.
I would suggest contacting Color Kinetics or a similar supplier of value-added lighting solutions for currently-available products which might meet your needs. “smart lighting” is a search term which may help you find additional options.
I am not a pro, but it definitely depends a lot on the LED strip voltage. You should determine it carefully. I was always afraid of the incidents that could occur because of electricity. If you are not accurate with the places, buying anything connected to electricity can end badly.
I am not a pro, but it definitely depends a lot on the LED strip voltage. You should determine it carefully. I was always afraid of the incidents that could occur because of electricity. If you are not accurate with the places, buying anything connected to electricity can end badly. I was always afraid of online shopping, but my sister is obsessed with it. Last month she ordered these wifi light bulb boxes on Amazon. Firstly I overreacted and judged her, but I got impressed by the lightning. The best part - it works with voice, and you can set timers. The bulbs are easier to use than to find PC driver connections, for sure.
