Pendant station - 4008 - 9001BW95Y - ND
Ordered this and part and received , found to have n/c and n/o momentary contacts . We assumed on ordering that both would have momentary n/o contacts which is our requirement . Can you please advise correct part number so we can re- order pendant station start/stop n/o momentary switching. appreciate an early response .
kind regards
Chris
Welcome to the DigiKey TechForum. Looking at the datasheet this pendant should have 2 NO contacts that are not interlocked . I wasn’t able to find a pendant switch with the function you listed , here is a link to the BW90 stations that may help in selection of the switch you need.
