Phoenix LED indictor on Terminal Block, What is the Voltage Rating?
Terminal block 3001938 from Phoenix Contact has the following image attached to it.
There has been some confusion regarding the voltage capabilities of this device as it is marked with +24V on the side. However, if we look at the product attributes section on the Digikey website we can see the following ratings
3001938
Terminal Block Connector 2 Position Disconnect Black 8-26 AWG
TYPE Ratings
Current - IEC 30 A
Voltage - IEC 250V
Current - UL 30 A
Voltage - UL 300V
Link to data sheet
Answer:
The reason this product is marked with a +24 on the side is because of the internal LED used to identify the presence of voltage within it. There are a few different versions of these to accommodate different voltage levels.
If you do not have a 24V power source and use it in an application that utilizes a higher voltage, the part does still meet the ratings above but be aware, exceeding the voltage rating will burn out the LED.
If you do not need the LED indicator the recommended course of action is to use the part that does not have an LED in it. However, if that is not possible because of sourcing issues, you could possibly use one of these other options here.
More Phoenix Contact parts this applies to:
ST 4 FSI/C Series
ST 4-FSI/C - 3036372
Digi-Key Part Number 277-2055-ND
Manufacturer Phoenix Contact
Manufacturer Product Number 3036372
LED No
LED Voltage None
Detailed Description Terminal Block Connector 2 Position Disconnect Black 10-28 AWG
ST 4-FSI/C-LED 12 - 3036495
Digi-Key Part Number 277-3912-ND
Manufacturer Product Number 3036495
LED Yes
LED Voltage 12VDC
ST 4-FSI/C-LED 24 - 3036505
Digi-Key Part Number 277-3549-ND
Manufacturer Product Number 3036505
LED Yes
LED Voltage 24VDC
ST 4-FSI/C-LED 48 - 3035250
Digi-Key Part Number 3035250-ND
Manufacturer Product Number 3035250
LED Yes
LED Voltage 48VDC
UK 6 FSI/C Series
UK 6-FSI/C - 3118203
Digi-Key Part Number 277-3228-ND
Manufacturer Product Number 3118203
LED No
LED Voltage None
Detailed Description Terminal Block Connector 2 Position Disconnect Black 8-26 AWG
UK 6-FSI/C-LED12 - 3001925
Digi-Key Part Number 277-3510-ND
Manufacturer Product Number 3001925
LED Yes
LED Voltage 12VDC
UK 6-FSI/C-LED24 - 3001938
Digi-Key Part Number 277-2339-ND
Manufacturer Product Number 3001938
LED Yes
LED Voltage 24VDC
UK 6-FSI/C-LED60 - 3001939
Digi-Key Part Number 3001939-ND
Manufacturer Product Number 3001939
LED Yes
LED Voltage 60VDC
PT 6-FSI/C Series
PT 6-FSI/C - 3212166
Digi-Key Part Number 277-3212166-ND
Manufacturer Product Number 3212166
LED No
LED Voltage None
Detailed Description Terminal Block Connector 2 Position Disconnect Black 8-20 AWG
PT 6-FSI/C-LED 12 - 3212169
Digi-Key Part Number 277-3212169-ND
Manufacturer Product Number 3212169
LED Yes
LED Voltage 12VDC
PT 6-FSI/C-LED 24 - 3212172
Digi-Key Part Number 277-17453-ND
Manufacturer Product Number 3212172
LED Yes
LED Voltage 24VDC
PT 6-FSI/C-LED 48 - 3212175
Digi-Key Part Number 277-3212175-ND
Manufacturer Product Number 3212175
LED Yes
LED Voltage 48VDC
PT 10-FSI/C Series
PT 10-FSI/C - 1088498
Digi-Key Part Number 277-1088498-ND
Manufacturer Product Number 1088498
LED No
LED Voltage None
Detailed Description Terminal Block Connector 2 Position Disconnect Black 6-20 AWG
PT 10-FSI/C-LED 12 - 1088499
Digi-Key Part Number 277-1088499-ND
Manufacturer Product Number 1088499
LED Yes
LED Voltage 12VDC
Detailed Description Terminal Terminal Block Connector 2 Position Disconnect Black 6-20 AWG
PT 10-FSI/C-LED 24 - 1088500
Digi-Key Part Number 277-1088500-ND
Manufacturer Product Number 1088500
LED Yes
LED Voltage 24VDC
PT 10-FSI/C-LED 48 - 1088501
Digi-Key Part Number 277-1088501-ND
Manufacturer Product Number 1088501
LED Yes
LED Voltage 48VDC
