To get this guy to work we need to download UF2 file. When I go trough the protocol of installment,
it opens a window saying that Adobe can’t open and trye Adobe Pro; I purchased and install Adobe Pro
but it still can’t open it. Is there other issue?
Hi @Loulou_Bob *.UF2 is a file format similar to a HEX file that the PICO uses for programming. I hope you can get a refund for Adobe Pro…
Please see the step’s here:
https://www.raspberrypi.org/documentation/rp2040/getting-started/#getting-started-with-micropython
You just need to push and hold the bootsel button till a RPI-RP2 device shows up in your windows drive manager, then drag and drop the *.uf2 file over the media.
Regards,
