Is there a way to edit the Ultra Librarian preset symbols? For me, the right-side pins always have the labels overlapping with the pins. This is an example with the LM2596S-ADJ/NOPB symbol. This is not an issue with custom symbols, but I don’t want to have to remake a symbol.
ULTRA LIBRARIAN Contact Us/Blog
Try the above link.
Thanks for your reply. I can try contacting them, but are you sure it’s not an issue on the Scheme-it side? In the part info, their symbol shows up normally. I’m not sure whether Scheme-it imports symbols from Ultra Librarian and converts it to their software.
@ha3 - Thanks for bringing this to our attention. I’ll pass the issue on to the Scheme-it team to look into.
@ha3 - Thank you for your patience. The pin naming location issue for Ultra Librarian symbols in Scheme-it has been resolved. You should now be able to insert the symbols without the name overlapping the pin connection points and wires on the right side.
Thank you for letting me know! I see it is indeed now fixed for LM2596S-ADJ/NOPB. However, I also had the IPS2050HQ-32 in my schematic, and I see that it still has the pin label overlap issue, even when I add in the symbol again. Was it just fixed for the LM2596S-ADJ/NOPB, or all Ultra Librarian symbols?
The issue was fixed for a large portion of the Ultra Librarian symbols. The team is still reviewing the library for cases that are still rendering incorrectly.
When adding IPS2050HQ-32 to a project, it loads correctly for me. Can you confirm this is the same part?
Can you try refreshing your browser or checking in an incognito window?
Yes, I’ve verified that it still happens for both of those
@ha3 - The team is working to reproduce and resolve this. In the meantime, we have added a couple symbol options to the library for part number IPS2050HQ-32.
