This is a board soldered connector, but if i found a simple one (cable terminal connector) will be great !
Wait for your feedback.
Hello and welcome to the forum, ricsilvasilva! Looking at this connector, I believe the closest equivalent in a cable-mounted version would be this part number: WM24062-ND
It can be difficult to find or guarantee a match across different manufacturers with connectors but this seems like a simple enough design that I’m fairly sure this will work. Please check the datasheet to verify that the sizing and everything matches up before purchase. Hope this helps!
