I have the Acton Research group SpectraPro-300i and I am looking for the power supply for it, or at least the connector for the input. The power supply the company used is the PUP30-25-H1-S 100-240V
Hello
Seems we don’t carry the PUP30-25-H1-S nor the SPECTRAPRO-300I and none of its associated line. I found the data sheet for the PUP30-25-H1-S here https://www.trumpower.com/library/pup30.pdf and used that to look for a cross but could only find one that is 2 outputs with 5V and 24V as the data sheet informs, and that also comes with the 5 pin DIN type output connector. That part is AEH45UM25-ND but it isn’t in stock. You can pull up the data sheet to review it closer and see if it will work for you, but there will be a lead time should you decide to order it.
Regards.
