PUP330N3-14 mating connector options
Is there a panel-mounted mating connector for the output connector of this PSU available? The output connector type is power DIN 4-pin, but it is female although usually they are male in the PSU side. I tried to look for a suitable mating connector with a panel mounting, but I didn’t find any.
Welcome to the DigiKey TechForum. I wasn’t able to find a panel mount male mating connector for this power supply. Do you have one of these power supplies in hand to verify the female output connector? From what I can tell this would be a pin style.
Agreeing with @Steve_Fellman that the connector on the PUP330N3-14 uses a power mini-DIN with male pins.
The mates would include the following:
KPJX-PM-4S
MFG_KPJX-PM-4S_tmb
KPJX-PM-4S-S
KPJX-PM-4S-S_tmb
I thought the same, but then I received the PSU and it has female sockets in the output connector.
I’m only finding cable mounted male pin connectors for this connection style.
