------Question for PUP330N3-14 Please Put your question below------
Does PUP330N3-14 have a locking mechanism in the output connector?
Hello Aleksi.Laiho,
The output connector of this power supply is a 4 pin DIN type and it does not have a lock latch or some other kind of locking mechanism. It is a simple friction style plug in.
Ok, thank you for confirming! Can I assume that if the datasheet does not mention a locking mechanism, there is none? Is friction locking the default?
Correct. If the Data sheet does not mention it, then there is no locking mechanism. Something like that would likely be in the drawing as well. The friction lock is for the most part standard on power supplies like this yes.
