Press fit tooling
------Question for SFPP-3130-L Please Put your question below------
What is the tooling part number to press this part into the PCB.
Hello smtelite,
There is no “recommended” installation tool for this device.
It is designed for a Press Fit mounting. So you would need some type of press or arbor device. You will also need a plate, to put even pressure on the part, while pushing it down into the circuit board.
Thanks David, usually when we are working with press fit parts a dedicated top piece is available. Molex for example provides a tooling for the part itself to ensure force is applied correctly. The base of course is customer based on the PCB design.
