Product Assistance
I need help finding this pin(see attached), it’s from a KTM dirt bike wiring harness. It’s for the fuel pump fuse, it’s a standard automotive 5a blade fuse. Maybe you could find it if KTM/Pierer Mobility has ordered them from you before. Part# 0913070001 is very close but not quite it.
Thank you for contacting the TechForum!
I think I got pretty close with these 2 options; these may not be exact but seem to be able to work.
2 closest options
5346-913-072CT-ND and 17-880397-2CT-ND
Thank you
Ryan
I think 5346-913-072CT-ND might work if I bend the tabs in, however I need it for 18-20 gauge.
I see the 18-20 gauge SKU shows obsolete, do you think the 14-16 will crimp down enough? Also will it fit in the same housing?
Hello Daniel.M
It is not recommended to use a contact for a larger gauge wire as it may not make good contact or any contact between the wire and the contact at the crimp.
I did check on Littlefue’s website and part number 913-070 is still an active part number. I have put in a request to have our website updated to show part number 913-070 from Littelfuse as an active part, but we do not have any stock of that part.
Okay thank you.
