Hi Team,
We have a requirement for the following items. Could you please support identifying the part numbers for them?
20x 4 pin - Amphenol Ecomate plugs male and female, both for cable installation
4x 7pin - Amphenol Ecomate plugs male and female, both for cable installation
3x 1mm2 Screened Cable Multi-Stranded
6x 1mm2 Screened Cable Multi-Stranded
100m of the 6 Wire Cable
500m of the 3 Wire Cable
Thank you,
Jeanneth
Hi jeanneth, welcome to the DigiKey TechForum
I provided some links below for options to choose from based on the descriptions provided. Mating connectors can be found at the bottom of the product page under “mating product”. You can find the associated contacts for a connector housing at the bottom of the page under “associated product”. For the connector assemblies, contacts are included unless stated other wise. FYI as you can see below, Amphenol has several different Ecomate series.
4p Ecomate connector housings - click HERE
4p Ecomate connector assemblies - click HERE
7p Ecomate connector housings - click HERE
7p Ecomate connector assemblies - click HERE
For some options of screened/sheilded cable that are approximately 1mm2 (or 17AWG), click HERE.
For 6 conductor cable, click HERE. I included options that are sold on 100m spools or options that we sell by the meter/feet.
For 3 conductor cable, click HERE. I included options that are sold on 499.9m spools or options that we sell by the meter/feet.
Please use the filters at the top of the page to narrow down the results and check the datasheets to ensure they will work for you.
Dear DigiKey,
Could someone please share a quotation for the items listed in the attached document? I am currently trying to upload this list through your portal, but the process is not working and I am unable to receive any results.
Kindly also confirm the lead time.
(attachments)
88023-Amphenol Ecomate Plugs.xlsx (17.6 KB)
Hello jeanneth,
Unfortunately we cannot provide quotes through the TechForum, please send this request to quotes@digikey.com and someone from our quote team will be able to assist you.
