Hello Experts,
I have an evaluation board with QTH-030-01-L-D-A connector and i have an adapter board with QTH-060-01-L-D-A connector on it. is it possible to use the adapter board connect only 60 pins to my eval board which has QTH-030-01-L-D-A? If so, what would be the cable configuration both ends? Appreciate your guidance.
Thanks
Thank you for your post.
It would be possible to use those with that adapter board, but it might be tricky. As far as the configuration is considered, that would entirely depend on your application and which traces need to be connected.
This would be something that is likely going to require some planning on your end to figure out which connections to make.
