I am searching for quality long life replacement capacitors for the ones shown in the following photos. They are used in a IP camera PoE switch that will function 24/7.
The 63V 470uF measures…
(D) 12.5mm x (H) 20mm x (SP) 5mm and is ESR rated.
Welcome to the DigiKey TechForum. For the 470uF capacitor take a look at DigiKey part 4191-EY1J471MP51220CT-ND , this is a 470uf, 63v, low ESR series with very similar dimensions. For the 330uF capacitor take a look at DigiKey part 1189-63ZLJ330M10X20-ND , this one is 330uF, 63v also with very similar dimensions.
Thank you for the timely response and product suggestions. They look like they will be a perfect replacement. I especially like the the 10,000 hour lifespan which is exactly what a 24/7 switch needs.
