Hi Robert,
I posted more messages:
//================= Good under VirtualBox Debian (4.19.0 kernel)
./quectel-CM -s ibasis.iot
[07-14_15:08:52:732] Quectel_QConnectManager_Linux_V1.5.9
[07-14_15:08:52:732] Find /sys/bus/usb/devices/1-2 idVendor=0x2c7c idProduct=0x296, bus=0x001, dev=0x003
[07-14_15:08:52:732] Auto find qmichannel = /dev/cdc-wdm0
[07-14_15:08:52:733] Auto find usbnet_adapter = wwp0s6u2i4
[07-14_15:08:52:733] netcard driver = qmi_wwan, driver version = 22-Aug-2005
[07-14_15:08:52:733] Modem works in QMI mode
[07-14_15:08:52:739] cdc_wdm_fd = 7
[07-14_15:08:52:782] Get clientWDS = 1
[07-14_15:08:52:790] Get clientDMS = 1
[07-14_15:08:52:798] Get clientNAS = 1
[07-14_15:08:52:806] Get clientUIM = 1
[07-14_15:08:52:814] Get clientWDA = 1
[07-14_15:08:52:822] requestBaseBandVersion BG96MAR02A10M1G
[07-14_15:08:52:854] requestGetSIMStatus SIMStatus: SIM_READY
[07-14_15:08:52:854] requestSetProfile[1] ibasis.iot///0
[07-14_15:08:52:880] requestGetProfile[1] ibasis.iot///0
[07-14_15:08:52:886] requestRegistrationState2 MCC: 310, MNC: 260, PS: Attached, DataCap: EDGE
[07-14_15:08:52:893] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[07-14_15:08:52:893] ifconfig wwp0s6u2i4 down
[07-14_15:08:52:919] ifconfig wwp0s6u2i4 0.0.0.0
[07-14_15:09:00:185] requestSetupDataCall WdsConnectionIPv4Handle: 0x83339490
[07-14_15:09:00:211] change mtu 1500 -> 1460
[07-14_15:09:00:211] ifconfig wwp0s6u2i4 up
[07-14_15:09:00:269] busybox udhcpc -f -n -q -t 5 -i wwp0s6u2i4
udhcpc: started, v1.30.1
udhcpc: sending discover
udhcpc: sending select for 10.165.77.108
udhcpc: lease of 10.165.77.108 obtained, lease time 7200
//========Device Instantiated
wwp0s6u2i4 : flags=4291<UP,BROADCAST,RUNNING,NOARP,MULTICAST> mtu 1460
inet 10.165.77.108 netmask 255.255.255.248 broadcast 10.165.77.111
inet6 fe80::cc1a:8cff:fe9d:6386 prefixlen 64 scopeid 0x20
ether ce:1a:8c:9d:63:86 txqueuelen 1000 (Ethernet)
RX packets 2 bytes 612 (612.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 24 bytes 3758 (3.6 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
//============================Failed on BBBw
[07-15_12:08:23:944] Quectel_QConnectManager_Linux_V1.5.9
[07-15_12:08:23:944] Find /sys/bus/usb/devices/1-2 idVendor=0x2c7c idProduct=0x296, bus=0x001, dev=0x003
[07-15_12:08:23:944] Auto find qmichannel = /dev/cdc-wdm0
[07-15_12:08:23:944] Auto find usbnet_adapter = wwp0s6u2i4
[07-15_12:08:23:944] netcard driver = qmi_wwan, driver version = 22-Aug-2005
[07-15_12:08:23:944] Modem works in QMI mode
[07-15_12:08:23:950] /proc/2287/fd/7 -> /dev/cdc-wdm0
[07-15_12:08:23:950] /proc/2287/exe -> /usr/lib/libqmi/qmi-proxy
[07-15_12:08:25:950] cdc_wdm_fd = 7
[07-15_12:08:26:037] QmiWwanThread read=-1 errno: 11 (Resource temporarily unavailable)
[07-15_12:08:26:979] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
[07-15_12:08:28:039] Get clientWDS = 1
[07-15_12:08:28:047] Get clientDMS = 5
[07-15_12:08:28:055] Get clientNAS = 1
[07-15_12:08:28:063] Get clientUIM = 1
[07-15_12:08:28:071] Get clientWDA = 1
[07-15_12:08:28:079] requestBaseBandVersion BG96MAR02A07M1G
[07-15_12:08:28:111] requestGetSIMStatus SIMStatus: SIM_READY
[07-15_12:08:28:111] requestSetProfile[1] ibasis.iot///0
[07-15_12:08:28:131] requestGetProfile[1] ibasis.iot///0
[07-15_12:08:28:139] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[07-15_12:08:28:147] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[07-15_12:08:28:147] ifconfig wwp0s6u2i4 down
[07-15_12:08:28:268] ifconfig wwp0s6u2i4 0.0.0.0
[07-15_12:08:34:118] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW
[07-15_12:08:40:079] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: EDGE
[07-15_12:08:40:086] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: EDGE
[07-15_12:08:44:807] requestRegistrationState2 MCC: 310, MNC: 260, PS: Attached, DataCap: EDGE
[07-15_12:08:45:664] requestSetupDataCall WdsConnectionIPv4Handle: 0x833c9b80
[07-15_12:08:45:687] change mtu 1500 -> 1460
[07-15_12:08:45:688] ifconfig wwp0s6u2i4 up
[07-15_12:08:45:742] busybox udhcpc -f -n -q -t 5 -i wwp0s6u2i4
udhcpc: no lease, failing
ONLY as PPP:
wwan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1460
inet 10.165.71.173 netmask 255.255.255.252 destination 10.165.71.173
inet6 fe80::c6eb:eaa0:60fa:5f22 prefixlen 64 scopeid 0x20
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
TX packets 39 bytes 6728 (6.5 KiB)
Yes, I have libqmi-utils installed.
I was also using qmicli commands, but no help.
[07-16_06:30:29:841] change mtu 1500 -> 1460
[07-16_06:30:29:847] ifconfig wwan0 up
[07-16_06:30:29:887] busybox udhcpc -f -n -q -t 5 -i wwan0
///=======MY NOTE: no lease for the first time. If got lease, it is in broadcast mode
//=======Then try and second time, it got PPP ip address.
[07-16_06:30:45:200] File:ql_raw_ip_mode_check Line:105 udhcpc fail to get ip address, try next:
[07-16_06:30:45:202] ifconfig wwan0 down
[07-16_06:30:45:255] echo Y > /sys/class/net/wwan0/qmi/raw_ip
[07-16_06:30:45:267] ifconfig wwan0 up
[07-16_06:30:45:317] busybox udhcpc -f -n -q -t 5 -i wwan0
udhcpc: sending select for 10.165.94.253
udhcpc: lease of 10.165.94.253 obtained, lease time 7200
ip: RTNETLINK answers: File exists
One thing I debugged:
in /sys/class/net/wwan0/qmi/raw_ip
Y
read(fd, mode, 2);
if (mode[0] == ‘0’ || mode[0] == ‘N’) { //////MY NOTE: raw_ip is Y, I don’t know why it runs this block of code:
dbg_time(“File:%s Line:%d udhcpc fail to get ip address, try next:”, func, LINE);
snprintf(shell_cmd, sizeof(shell_cmd), “ifconfig %s down”, ifname);
ql_system(shell_cmd);
dbg_time(“echo Y > /sys/class/net/%s/qmi/raw_ip”, ifname);
mode[0] = ‘Y’;
write(fd, mode, 2);
mode_change = 1;
snprintf(shell_cmd, sizeof(shell_cmd), “ifconfig %s up”, ifname);
Thank you,
David
