Question lcd led ips display
display IPS LED LCD is not energized frequently and is stored for many years without use, the liquid crystals will go to sleep and will not respond correctly. Will it generate problems with the pixels and permanent image retention because not use long periods? i have little handheld consoles with display lcd led ips
Modify message
Hello cloudff7,
I’ve had a lot of meters and devices with LCD displays, and have not had any trouble using them after sitting for years at times. I think as long as they are stored within the normal operating temperature, there shouldn’t be a problem. Maybe one of the engineers can add to this post with their knowledge on the issue.
In long-term storage years without use of the IPS LED LCD panel, the liquid crystals suffer from dead pixel, evaporation or degradation of the liquid crystal materials, Failure of the TFT transistors? and backlight and leds defects for longtime s
torage?
If you store an any IPS LED LCD panel without using it for a long time (many years), will the pixels develop dead and stuck pixels? Can liquid crystals settle over time, leading to slow response times or “stuckness”, where they may not change state correctly when turned on after years of inactivity? Do LEDs and backlights die or lose efficiency?
@cloudff7 DigiKey is a component distributor of millions of parts, we offer technical assistant to our customers.
For theoretical questions, you should really consulate with researches or universities.
Closing thread.
Regards,
