we are currently using this line of code to open a Solenoid lock using voice activation, however it is taking forever to recognize and is stuck on ‘listening’. How would we make it faster?
or if we were to use an offline speech recognition, what is the code that will yield the same function?
this is operated in a raspberry pi 3 through python and executed through cd Desktop
import RPi.GPIO as GPIO
import time
import speech_recognition as sr
# Configure Varaibles
command = ""
password = "open this door please"
voiceOK = False
r = sr.Recognizer()
# Configure GPIO
solenoidPin = 4
GPIO.setmode(GPIO.BCM)
GPIO.setup(solenoidPin, GPIO.OUT)
GPIO.output(solenoidPin, GPIO.LOW)
while(1):
with sr.Microphone() as source:
voiceOK = False
# Keep running until the voice is understood by Google
while(voiceOK == False):
print("Speak:")
audio = r.listen(source)
try:
speechString = r.recognize_google(audio)
print(speechString)
voiceOK = True
except sr.UnknownValueError:
print("Could not understand audio")
except sr.RequestError as e:
print("Could not request results; {0}".format(e))
# Determine if the password is correct
if(speechString == password):
GPIO.output(solenoidPin, GPIO.HIGH)
print("ACCESS GRANTED")
time.sleep(2)
else:
print("ACCESS DENIED")
