I need help identifying this 3 position connector for replacement fans that I’m buying. I’m including 3 photos. Thanks in advance if you can help.
The connector housing looks similar to the housings on this link https://www.digikey.com/short/zhc5370n.
The crimp contacts are sold separate, the contacts can be found on the product page for the connector housing.
There are also ready cable assemblies in stock with XHP-3 type connectors:, like:
Product part number: XHP410070M7MLX3(R)
Datasheet: https://globtek.secure.force.com/spec/pdf/792861/d2323466
DigiKey Link:
