Hello All,
I often has problem with these reed relays, it got stuck when actuating the coil. Would you please comment on what would be the best replacement parts, since we don’t want to re-spin the boards.
thanks
Danny
Hello All,
thanks
Danny
Greetings,
Sticky relays commonly indicate application of a relay outside it’s capacity; if that’s the case then whatever you’d use in this part’s place is likely to suffer the same fate.
If you’d be willing to describe the switched load (schematic would be nice…) some more specific guidance could be offered.
