Reflective sensor modules
Hi,
due to assembly/processing i am looking for a reflective sensor, similar to GP2A200LCS0F SHARP/Socle Technology | Sensors, Transducers | DigiKey BUT with assembly from the other side. Not from the “object to be sensed” side, but from the rear side.
Green - housing; dark green/grey - sensor; violet - screws.
Any suggestions?
The Datasheet lists the Reflective object as:
Black paper (black) : Standard reflective object (provided by SHARP Corporation)
KODAK Gray Cards (use the white side reflects about 90%)
PPC paper : Standard reflective object (provided by SHARP Corporation)
Hi, I don’t follow, sorry.
I need the sensor to be sensing in the same direction as it is assembled. See my picture above.
Unfortunately, these are the only chassis mount reflective options:
Reflective - Logic Output
Reflective - Analog Output
