Regarding the soldering of the backside electrode of the pSemi PE4140
------Question for PE4140B-Z Please Put your question below------
Hello.
Regarding soldering the pSemi PE4140, is soldering required at the red-circled area in the attached image? Also, what is the function of this electrode?
Hello osawa.yutaro,
Welcome and thank you for posting on the TechForum.
I did some looking into this and the solder pads on the side do not need to be soldered. From what I read they have no electrical value .
Hi jeff.
Thank you for your confirmation.
We were unable to confirm the role of these pads in the datasheet. Is the exposed solder pad at the center of the back surface sufficient for heat dissipation, RF grounding, and mechanical fixation? If necessary, please get in touch with the manufacturer.
The center pad underneath does that stuff. The ones on the sides if soldered can cause unwanted grounding, stress cracking or other issues.
Thank you for your response.
I understand.
Thank you.
