Replacement pushbutton switch
Looking for help to identify suitable replacement switch for Sony tuner : front panel mount power switch. Has markings on circuit board S901, and TV-3 JP34 on front mount bracket
Hello kubra1.gr,
Unfortunately, I have been unable to find anything based on the provided information. If you are able to provide more information regarding the specifications of the switch and/or images, it may assist in finding a suitable replacement.
Thanks for the follow up Nick, here’s a couple of pics.
Thank you for the images kubra1.gr.
Unfortunately, I have been unable to find anything that matches the specificaitons I was able to find using the pictures.
Hi kubra1.gr,
I didn’t see anything that appeared to be an exact match, but here’s a link which has some similar parts. Perhaps you could hack something together with one of these if you can’t find an exact match.
Alternatively, you might check the used products market online to see if someone might be parting out an old unit.
Thanks for the follow up David…
