Looking for a replacement lighted switch for coffee maker model # BVMC S05BL2. Markings on the switch are JL KDZ-8 T125
Thanks
Thank you for your inquiry and welcome to the community.
Appears this switch is going to be custom for Mr. Coffee.
I checked our illuminated rocker switches and I didn’t see anything with that power rating in a similar form factor.
I also checked all the companies that Mr. Coffee listed as carrying spare parts and didn’t see the power switch listed as an option for replacement parts.
These switches are commonly used in appliances like slow cookers and coffee makers. Finding a replacement lighted switch for your Mr. Coffee model BVMC-S05BL2 coffee maker, marked with “JL KDZ-8 T125,” may not be possible due to limited availability of exact matches. However, similar switches, such as the JL KCD-3 T125, are available and may serve as suitable replacements, depending on compatibility.
There are T125 Switches on Amazon. You can see if these are close to Mr. Coffee maker switch in terms of dimension and specs.
If you want to make a pcb to automate the coffee machine, you can see here:
Thanks, It looks like I’ll have to modify the switch housing to get something that fits. This will be the back up coffee maker…
