Finding a Replacement for An OEM rocker switch
The Mr. Coffee switch has a Led in the rocker, three spade wire connections on the bottom.
It is panel mount, snaps in. The part number appears to be JLCD-2, 16A, 125 VAC. Also stamped
into the body is T125. Can you tell me what part number and Manufacture(s) would have a switch like this.
Hello Msgt95,
Thank you for your inquiry. I wasn’t able to identify the exact switch, please review if one of below will work for you:
https://www.digikey.com/short/n9v70zjc
Otherwise a photo or measurements may help to determine the switch.
