------Question for 1-5499206-0 Please
Good morning, we need one or more MPNs for a 50-pin female-to-female flat cable, with a length in the 30 cm to 50 cm range, that is compatible with this connector: AHK50B-ND. Put your question below------
Your Suggested Part Number AHK50B-ND will not work with a cable, that connector is intended to be soldered to a printed circuit board.
Understanding the request as being for cable assemblies that are mate-compatible with the connector mentioned, one may consider these listings as potential candidates. Cross-vendor interoperability is fairly common for connectors of the type, but should be validated.
Please note that due to recent discontinuance of some services, listings shown as a “Value Added Item” are no longer available unless stock is indicated, and in such cases those items will no longer be available once the existing stock is depleted.
