Resister ID
Found a bad resister on an induction burner control board. Trying to confirm the value and find it in the zillion resisters you sell…
The second photo is of a good one.
Do you have a multimeter that you can use to measure the good resistor out of circuit?
I can, but was hoping not to have to pull it out…
I did pull the bad one out and it tested open. looks like a 39 ohm, from the bands, measures 15mm x 5 mm.
@apolillo
I found the WW3FT39R0CT-ND for the 39Ω 1% item.
WW3FT39R0 Stackpole Electronics Inc | Resistors | DigiKey
