Rocker switch direct replacement
Hello, I’m looking for an available replacement (same specs and dimensions) for this particular rocker switch. Thanks, Curt
Hello curtstadel, welcome to the TechForum.
Take a look at part number 708-3036-ND See if it what you are looking for.
If the above mentioned switch is not a good fit, perhaps providing some specs, such as approximate panel cut-out dimensions, might help narrow down the options.
