Scheme-it - Rotate a part in your schematic
May I know how to rotate a symbol?
Right click on the part and select rotate, or click on the part and click the “R” button on your keypad and the part will rotate. This may be done multiple times if you need additional rotation on the part. Note: Custom symbols do not have this feature available.
  1. Right click on the part and scroll down to rotate
  2. After you click rotate you will see that the part has rotated
Parts are only able to rotate in 90 degree increments.
Wanted to add that, sometimes it is more favorable to use the V & H to flip the symbol/object…
