Hi … I am looking for the male MDR connector to mate with a panel mount female 68-pin MDR connector which has screw nuts on the sides.
The male connector that I am looking for will be terminated with a round multicore cable of about 9mm in diameter. It will only use 6 designated pins on the connector to service a 2 Channel digital audio setup.
I think I found the hood part which seems to be:
I am assuming this conforms to the MDR physical specs.
Now, I need the male plug part to go inside it with a solder type on the back of it.
Searched high and low and only found female PCB type connectors that is not what I am looking for.
I found this one. Seems to be a male MDR connector … will this go into the Hood part I found earlier?
This is a solder version which is what I am after.
Hmm… just noticed that the plug is a board edge/ straddle mount plug. It is missing the side holes for the screws to come through? I doubt this will fit in that Hirose connector … unless someone can check it at your end? I am thinking now that this is not the right plug. Needs a plug suitable for external cable shell. This is quite tricky!
Actually I think it may work so would it be possible for someone in tech to check the compatibility, and if it works out, I will place my order. Thank you Verna_1353.
