Has anyone experienced reflow issue with this solder charge connector?
I have a proper lead-profile, but I am seeing a lot of pins lacking a proper solder connection.
Thank you for contacting the TechForum. We are looking into this request and will get back to you as soon as we can.
Thank you
Ryan
Hi fernandon,
Curious about the solder profile you used for this part. This part appears to have tin/lead-based solder so the peak temperature of your profile probably should be somewhat lower than one would use with a lead-free profile.
From the datasheet:
If you need the Lead-Free version, then the SEAM-40-11.0-S-10-2-A-K-TR would be the otherwise identical option.
Here is some further information on soldering the Samtec Searay products.
Hello @fernandon
If you could send an email to Applications.Engineering@digikey.com with more information on this issue, we can reach out to Samtec for more support on this issue with part number SEAM-40-11.0-S-10-1-A-K-TR.
Yes, I am now working with the component manufacture. Thanks.
