Serpac product availability
Hi DigiKey Team!
I would like to know if it is possible to order a specific Serpac enclosure through DigiKey.
The black variant of the product is available on digikey here:
However, I’m looking for the product code “031C,BK”.
This is the exact same enclosure, except that that top clover is clear.
This enclosure is available on Serpac’s website.
We do not require any customization, just looking for this clear variant.
An image is available here:
Thanks!
Hello @fusion
Welcome to community!
Sorry, I am unable to find the part ‘031C.BK’. If you are looking for a clear cover, please note that the height of the enclosure will change. Check the link for the available parts.
Boxes Serpac | Electronic Components Distributor DigiKey
Hi @aayushi.nainwal
Correct, it is not available in your catalog. Part # 032C-BK is almost the same, but taller, as you mentioned. 031C.BK is the 0.9" height version.
Is there a way to request 031C.BK through DigiKey even if it isn’t currently in your stock/catalog?
Greetings,
This part is not carried by DigiKey. We are unable to process a quote or order for this item.
Thanks for the info.
If you can find it on the Serpac website you should be able to order it directly from them.
